You could use 40mm, but this might be a bit confusing, as you are only allowed 12mm of weld metal thickness. You could limit it to 12mm. 12mm is usually plenty thick for a GTAW procedure. You could always use QW-200.4 if a thicker base metal needs to be welded.
