e43u8
Chemical
- Feb 23, 2008
- 134
In the thread with the subject of "API 650 statement" LittleInch has provided following statement from API 650:
Appendix F states that if the pressure is less than 1kPa (4 inches of water), then it is classed as "atmospheric" Design pressure higher than that up to 18 kPa needs Appendix F to be applied.[unquote]
i have the Edition of 2007 in which i don't find such statement especially the first part about the design pressure of less than 1kpa which doesn't need using appendix F.
I want to know such statement can be found in which Edition of API 650?
