Minimum Number of Elements Through Thickness for Stress Linearisation 1
Mohit_singh
IN
Hi ALl,
I am doing FEA of a Nozzle using ASME VIII div 2 . Now I know from someone that we have to take minimum three elements along the thickness for Proper Analysis. Can someone give me ASME reference to the same ?
There is nothing in the ASME Code that will replace your engineering judgement. 3 elements in the through-thickness direction would be a minimum IF you were using quadratic elements. 3 linear elements through-thickness would be completely unacceptable, however.
The matter is that you need to adequately define the through-thickness stress distribution, including both the linear and non-linear portions - especially if your pseudo-elastic stresses exceed yield.
Much more discussion on this topic can be found in ASME Section VIII, Division 2, Part 5, Annex 5-A.
Also, please remember that you must meet the requirements of ALL of Part 5, which includes Paragraphs 5.2, 5.3, 5.4, 5.5, and particularly for nozzles, section 5.6.
Thanks TGS4 for your answer. However if I am using linear elements than how many elements are acceptable?
You're the engineer - you tell me.
HUH!! I use more than three elements as the WRC 429 and ASME PTB uses in its examples.
First, you need to ensure that your solution is mesh independent. In general, I don't think that three linear elements through-thickness is adequate. Depending on the situation, 10 or more may be needed. There are no rules, just engineering judgement - and your judgement needs to withstand severe scrutiny.
Second, I sure hope that your linear elements are not tetrahedrals.
Third, the examples in PTB-1 all use quadratic elements.
