Karol Jimena
Petroleum
Good morning Engs.,
I have a situation:
I have a double vertical drum with an internal cap, this head is the superior head of first drum and the same head is the inferior head of second drum.
I need to calculate the minimum thickness req. of the internal head, but in asme sec VIII UG 32,28, 27 is related to Presion of system: 890 Psi, and the the nominal thickness of shell is 1.375", External head is 1.3125", and the internal head is 0.750".
The material is A 515 Gr 70, S=17.500 Psi, the I.D. is 48".
Please your help, how to calculate or estimate the minimum thickness req for internal head. I attach a image.
Thank you
I have a situation:
Thank you
