Greatings All,
Does it exist some code that allows to determine the minimum thickness of a beam or know guidelines with criterion to remove beams affected by the corrosion? For example, there are several beams with deterioration by corrosion with material loss which can convert in a serious working risk or operational, whence needs a fast decision, always justificed under a code or criterion.
Thanks in Advance.
Thanks in Advance.
