mirror text
JBIM
Industrial
Nov 22, 2006
89
I ask about mirror text in drafting and had a few answer:
here is an another way:
in drafting , pick the view you want to write the mirrored text and enter expand member view .
then insert text and rotate it 180º like if you were in modeling.
that it.
Rotating 180° will not MIRROR text, it will only make it upside down, not backwards. If you mean rotating BETWEEN 2 AXES, which something completely different. Rotating Between 2 Axes will make the text appear to be a "mirror image" of what it would normally be when placed on the XY plane.
Tim Flater
Senior Designer
Enkei America, Inc.
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
I have sucessfully tackled this by rotating the text 180 degrees about the y axis. I like Tim's solution also. Many ways ...
