Yoshimitsu
Petroleum
- Feb 13, 2013
- 2
Hello friends!
I wish to know, how it's possible this difference in the OD of a spacer between the ASME code 16.48 and the PipeData Pro software, which is based in the same code ASME 16.48.
PIPEDATA ASME 16.48
6" ID 159 mm 168 mm
OD 219 mm 219 mm
10" ID 260 mm 273 mm
OD 337 mm 337 mm
Which one is the correct one?
Thanks in advance,
David
PIPEDATA ASME 16.48
6" ID 159 mm 168 mm
OD 219 mm 219 mm
OD 337 mm 337 mm
Thanks in advance,
David
