Feb 7, 2008 #1 lfc09 Mechanical Oct 24, 2007 9 0 0 US Do supply and return dampers on a mixing box for an AC Unit have to be physical connected using linkage? Is there a way to link them via motor controller?
Feb 7, 2008 #2 AbbyNormal Mechanical Nov 17, 2003 780 0 0 KY yes. if you wanted to, you could have two motors Take the "V" out of HVAC and you are left with a HAC(k) job. Upvote 0 Downvote
Feb 7, 2008 #3 imok2 Mechanical Oct 21, 2003 1,311 0 0 US You could have one controller and one motor with linkage to two dampers fact is, there are many combinations you can use. Upvote 0 Downvote
