RobertHale
I am trying to figure out what the ASCE 7-16 code intends for MRSA drift calculations.
Looking at section 12.9.1.4.2 of the code you have the following:
Furthermore, Looking at Equation 12.8-6, you have:
Based on those two provisions, is the intention NOT to scale the base shear for drift if you have a structure on a site where S1<0.6g or where Equation 12.8-6 doesn't control? Or is the intention to artificially perform a base shear calculation with the equation referenced (i.e. V' = [0.5*S1*Ie/R ]*W), then compare that with the modal base shear and scale if appropriate?
Thanks for any insight in advance.
Robert Hale, PE
Robert Hale, PE
