Model Limits
arb6591
Is there any way to change model extents or limits so when I hit F it zooms in to what I see on the screen ?
When I hit F my whole assy zooms out and takes maybe 10% of the screen area but I have no parts visible there.
Anybody has any ideas?
There is an Origin, Sketch, point or something that is out there... and that would be why your Zoom Fit is like that.
If you remove or hide the problem, then your Zoom to Fit will work better.
Scott Baugh, CSWP [pc2]
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
You might also look at the extents of the planes. You can drag them to size their "boundaries". This will affect the zoom even if the planes are not displayed.
- - -Dennyd
I found this happens when I drag a sketch from another model sometimes.
