Siva Thaya
- Apr 25, 2020
- 1
As the ground settle (sketch is attached), the masonry wall(brick wall) try to deform to follow the ground settlement profile. I tried to model the wall as plate element in STAAD model and apply enforce command to the support.The result is not in correct format (stress contour is attached). Do you have any idea how to model it in STAAD Pro correctly and what commands should be used?
