Hello all,
I would like to use a Table from CSV function, but after insertion I would like to modify column sizes of that table.
What I would expect: I select the table --> run the macro --> table modified
In the macro there would be that column 1 should be XXmm size; column 2 XXmm and so on.
Is anyone able to do that? I have tried record macro, but resizing was not recorded.
Thank you in advance
