Modify 2D multiples headSymbol -CAT/VBA
Samrou
New member
TN
Hi ,
I'm created a macro that modify items dimension in 2D page(drafting) but What I couldn't achieve is to modify all headliner for the related items see image below
My code modify only 1 point :
Code:
 Dim myview As DrawingView
  Set myview = CATIA.ActiveDocument.Sheets.ActiveSheet.Views.ActiveView
  Dim mytext As DrawingText
  Set mytext = myview.Texts.Item(1)
  Dim myleader As DrawingLeader
  Set myleader = mytext.Leaders.Item(1)
  myleader.HeadSymbol = 0 ' this line is to modify the point as mentioned in the image
'the problem that this code is modifying only point and I want to modify multiple points
Anyone can light me on this ?
Please feel free to ask for clarification "My first post here "
B.R
S
Code:
Gets the first element of the Texts collection.
so if you want to modify the second text, you should do
Code:
Set mytext = myview.Texts.Item(2)
once the first point is modified.
Or if you want to modify all points, you should loop and use something like this
Code:
 for i = 1 to myview.Texts.Count
[indent]Set mytext = myview.Texts.Item(i)
[...][/indent]
next
Eric N.
I'm not sure if I understood you well, but I suppose you want to modify multiple text leaders. You would need to loop ".Texts" collection and modify each individual text leader. "Texts.Item(1)" means only one text, first text from ."Texts" collection.
