Modify a journal that run in native mode. So to be run also in manager Mode.
Ehaviv
Computer
IL
Hi
This journal run OK in native mode. and I want to modify it so its work also in manager mod.
I tried as shown in bolt text but that fail to run.
Please help to make it run in manager.
Thank you in advanced.
Code:
'                                            010919_1654
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Module part_export_with_options
 Dim cnt as Integer = 0
 Sub Main()
   Dim theSession As Session = Session.GetSession()
   Dim theUFSession As UFSession = UFSession.GetUFSession()
   Dim abody() As TaggedObject = Nothing
   Dim bodyTags As New List(Of Tag)
   Dim options As UFPart.ExportOptions
   Dim dp as Part = Nothing
   Dim wp as Part = Nothing
   Dim newExportParName As String = Nothing
   Dim cnt As Integer = 0
   Dim nowDateTime As String = Nothing
   Dim sfxBnum As Integer
   Dim rand As New Random()
   Dim internal_part_name As String = Nothing
   wp = theSession.Parts.Work
   dp = theSession.Parts.display
   nowDateTime = Format(Now, "_ddMMyy_hhmmss_")
   sfxBnum = rand.Next(1000, 8000)
   newExportParName = wp.FullPath.Replace(".prt", "_export" & nowDateTime & sfxBnum & ".prt")  ' for native mode
[b]   'newExportParName = "DB/export" & nowDateTime & sfxBnum & "/-")                             ' 1 for manager mode
   'Try
   '  ufs.UGmgr.ConvertNameFromCli(newExportParName, internal_part_name)
   'Catch e As NXException
   '  lw.WriteFullLine("The Import process failed Message = " & e.Message)
   'End Try
   'newExportParName = internal_part_name                                                       ' 2 for manager mode
[/b]
   If SelectBodies("select bodies", abody) = Selection.Response.Cancel Then
     Return
   End If
   For Each temp As TaggedObject In abody
     bodyTags.Add(temp.Tag)
   Next
   With options
     .new_part = True
     .params_mode = UFPart.ExportParamsMode.MaintainParams  ' RemoveParams
     .expression_mode = UFPart.ExportExpMode.CopyExpDeeply  ' CopyExpShallowly
   End With
   theUFSession.Part.ExportWithOptions(newExportParName, _
                                       bodyTags.ToArray.Length, bodyTags.ToArray, options)
 End Sub
 Function SelectBodies(ByVal prompt As String, ByRef selObj() As TaggedObject) As Selection.Response
   Dim theUI As UI = UI.GetUI
   Dim title As String = "Select one or more bodies"
   Dim includeFeatures As Boolean = False
   Dim keepHighlighted As Boolean = False
   Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
   Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
   Dim selectionMask_array(0) As Selection.MaskTriple
   With selectionMask_array(0)
     .Type = UFConstants.UF_solid_type
     .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_BODY
   End With
   Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObjects(prompt, _
                                                              title, scope, selAction, _
                            includeFeatures, keepHighlighted, selectionMask_array, selobj)
   If resp = Selection.Response.Ok Then
     Return Selection.Response.Ok
   Else
     Return Selection.Response.Cancel
   End If
 End Function
 Public Function GetUnloadOption(ByVal dummy As String) As Integer
   GetUnloadOption = UFConstants.UF_UNLOAD_IMMEDIATELY
 End Function
End Module
I'm not going to try debug your existing program, because I'm probably not the right one to do that, but I did create a program a long time back (NX 5/2010 - forget which Tc we used) that was used to do certain verifications of Managed data.
When I tested the program, however, I ran it in native. The easy way out for me was to add code to automatically detect this, rather than have to modify the program for Test or Production.
The key for Managed is to call out the part name using the CLI format that Tc uses, so it can find the item in the Tc DB by partnumber.
Below is the code that was relevant to this checking section of my VB program.
I see I had note in their that it sometimes failed for me. I have no memory of that, and it may have been due to older NX and Tc, so no idea if that is important for your case or not. You might ignore that to start.
Maybe this has hints to get you started:
[pre]'
' Get Mode, Managed or Native
Try
theUfSession.UF.IsUgmanagerActive(managedMode)
'listingWindow.WriteLine("managedMode : " & managedMode)
Catch ex As Exception
' The Managed detection seems to fail sometimes, maybe a timeout or something
managedMode = True
listingWindow.WriteLine("Could not detect Native/Managed mode, so assuming Managed")
theSession.LogFile.WriteLine("Could not detect Native/Managed mode, so assuming Managed")
End Try
' Open Part
If managedMode Then
' Managed Mode: Build Partname, Open, and Status/Error Check
' Managed (CLI) format = "@DB@PRE_30492_num@-.001"
' Mar. 15, 2010 - Change from original format, with "/" to "@"
' solve prolblem when Part Number contains a "/"
' i.e. original format = "@DB/PRE_30492_num/-.001"
partName = String.Concat("@DB@" , _
itemID , _
"@" , _
nxRevID )
listingWindow.WriteLine("processing (managed) : " & partName)
' theSession.Parts.SetNonmasterSeedPartData(partName)
basePart1 = theSession.Parts.OpenBaseDisplay(partName , partLoadStatus1)
openFlag = 1
' listingWindow.WriteLine("NumUnloaded : " & Cstr(partLoadStatus1.NumberUnloadedParts))
If partLoadStatus1.NumberUnloadedParts Then '1 => the part failed to load; 0=>part loaded
listingWindow.WriteLine("Failed to Open Part " & partName)
theSession.LogFile.WriteLine("Failed to Open Part " & partName)
statusFlag = String.Concat("Failure")
statusMsg = String.Concat("Part Open Failure")
openFlag = 0
End If
Else
' Native mode: Build Partname, Open, and Status/Error Check
' Native format = "D:\work5\Verify\Export\PRE_30492_num.prt" (%VERIFY_HOME%="D:\work5\Verify")
' (native parts must be stored in %VERIFY_HOME%\export\)
partName = String.Concat(pathVar, _
"\Export\", _
itemID , _
".prt" )
listingWindow.WriteLine("processing (native) : " & partName)
Try
openFlag = 1
theSession.LogFile.WriteLine("Error: ")
theSession.LogFile.WriteLine(ex.GetBaseException.ToString())
openFlag = 0
End Try
End If
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display[/pre]
Hi CADPat and thank you very much.
In my above journal.
I used CLI format (see the first commented
Bolt line)
and I do a test in managed platform.
The issue is the nx UF function:
Do it compatible to managed mode or not.
This is why I tried also the internal file format.
If you're journal do export a part in
Managed mode . I will happily use it.
Thank you again.
