FreshMan2020
- May 7, 2020
- 24
I have this flat slab sitting on top of forest RC columns. A couple internal columns fail in minor axis under gravity loads unless I increase the width of the column, which the client is not happy to do. My question is, can I modify the column stiffness (say 0.35 Ig) to let it 'crack' so it will attract less bending moments and thus pass? (I will design the slab accordingly and the column wont be used for lateral purpose) If yes, what the crack will be like, will it lead to any failure and if there is any particular connection detail required for column-slab? If no, why can we modify the out-of-plane stiffness of RC walls?
