thread560-358816
Hi
the code works great,
another scenario is when there are two fields with the same text, the two are replaced, and in my case I wanted only one to be changed.
is it possible to saddle the text with mause, and only change what is selected? in my case I can blow the block.
Sub CATMain()
Dim oDrawing As DrawingDocument
Set oDrawing = CATIA.ActiveDocument
Dim oSheets As DrawingSheets
Set oSheets = oDrawing.Sheets
Dim oSheet As DrawingSheet
Set oSheet = oSheets.Item("Sheet.1")
Dim oView As DrawingView
Set oView = oSheet.Views.Item(2)
oView.Activate
Dim o2DComponents As DrawingComponents
Set o2DComponents = oView.Components
Dim o2DComponent As DrawingComponent
Set o2DComponent = o2DComponents.Item(1)
' Retrieve the modifiable text of the ditto
Dim oText As DrawingText
Set oText = o2DComponent.GetModifiableObject(1)
Count = o2DComponent.GetModifiableObjectsCount
For i = 1 To Count
Set oText = o2DComponent.GetModifiableObject(i)
If oText.Text = "Text 1" Then
oText.Text = "A1"
ElseIf oText.Text = "Text 2" Then
oText.Text = "B1"
ElseIf oText.Text = "Text 3" Then
oText.Text = "C1"
ElseIf oText.Text = "Text 4" Then
oText.Text = "D1"
ElseIf oText.Text = "Text 5" Then
oText.Text = "E1"
End If
Next ''i
End Sub
Hi
Sub CATMain()
oView.Activate
For i = 1 To Count
oText.Text = "A1"
oText.Text = "B1"
oText.Text = "C1"
oText.Text = "D1"
oText.Text = "E1"
End If
Next ''i
End Sub
