wrxsti
- Sep 18, 2020
- 196
hello eng tips community
i wanted your opinion on modifying an existing RHS Beam with RHS knee braces.
for new building load the RHS is not sufficient
proposal is to remove knee bracing put another beam under RHS connect at columns
reinstall knee bracing
the issue is can you cut the knee brace from the current rhs beam safely
and grind it down so allow proper mating of new underpinning beam.
