Moment capacity of HP12x53
HanStrulo
117
Hi Everybody,
I have a really simple question but for some reason i am doubting myself.
what is the moment capacity (allowable moment) for HP12x53 with a length of 5m (continuously supported)?
I am asking because in CISC, it's not even class 3 and i end up removing some flange width to get it to class 3 and then only use the Sx value to get the elastic moment. Am i missing something? Could we ever use the Zx with this section?
Does the AISC have a similar issue with the HP sections?
Thank you,
Never designed to CISC, and I have no clue what the classes of shapes are or what they mean.
Designing by AISC, an HP12x53 is slender in compression and has non-compact flanges for flexure - so you have to check for LTB and Compression Flange Local Buckling in addition to Yielding.
sorry for the confusion. I would like to just know the number you get (allowable moment) to compare against mine. I understand HP are not good in bending but all the reductions we make seem very limiting.
can it be designed using plastic moment or only elastic moment?
Thanks alot,
as a Class 4 section, only elastic.
@dik. Thank you. i get a similar number too. I only wanted to check because i did not want to be overdesigning it.
