Deener
- Aug 30, 2018
- 48
Hi All,
I have been asked to provide a moment connection detail for a pipe support composed of a W8x21 cantilevered beam off a W10x22 column. A325 bolted connection between bottom flange of beam and column cap plate.See image below. Typically when I detail a moment connection, the top flange is restrained by welding or bolting to another member. Not possible in this case. To properly restrain the beam and to minimize rotation at the support point, I believe my only choice is to add full depth web stiffeners which are a continuation of the column flanges below. Is this a relatively standard detail for a moment connection? Are the bolts in the bottom flange considered sufficient enough to be transferring the moment from the beam into the column?
