Suppose you have two bay frame in which the two beams are connected to column in the middle through moment connection. The beans are also connected to end colums through moment connection. Do you analyze this beak as a simple continuous beam? Does the moment connection makes the beam continuous? Also what forces are transferred to the centre column from the beams on both sides OR the moments get cancelled out from either sides?
