kaffy
- Jun 2, 2020
- 191
Good Morning fellow engineers,
I am working on a steel structure and trying to make a fixed connection on beam in order to reduce the required beam size as compared to pinned connection. Structural member acting as beam is a C channel. I was thinking to use two clip angles as shown in attached file. Idea is to attach the web of c channels with bolts and then flanges with clip angles. What do u guys think? Would u consider it as fixed connection? Any related reference will be appreciated.
Thank You
Kaffy
Thank You
Kaffy
