dccd
- Feb 19, 2021
- 150
Why for pinned end continuous beams subjected to UDL, the sagging moment tend to decreases when rigid zone is applied ?
My thought is when rigid zone = 0 applied, no part of the beam assumed to rigid, the stiffness of beam is still similar to beam when no rigid zone applied. It’s just that when rigid zone = 0 applied, moment was taken at the column face, hence moment at the column face is generally smaller than moment taken at the center node.
Since stiffness of beam is not affected, why the sagging moment is lower when rigid zone = 0 applied?
