Zachari_alamsyah
Dear all
What exactly the purposes of Monolithic Isolation Joint (MIJ) in Pipeline, is it effectively used in buried pipeline condition? Is the using of MIJ reduces the using of CP (cathodic Protection) at pipeline e.g Anode installation to prevent corrosion?
Is there also can substitute the using of Block valves to isolate pipelines , if there any leak occur?
Appreciate for your response
ZA
ZA
