I'm designing a monorail beam for a monorail crane. Crane capacity is 5T, span between supports is 25'. I've spec'd a W14x61 beam. Originally, the beam was to be mounted on top of header beams at each end. Unfortunately, these header beams are already in place and are too high for the monorail beam to sit above. I'm also told that the monorail beam can't hang below the header beams (bolted to their bottom flanges) because this wouldn't provide enough headroom under the monorail's hoist.
This leaves me with attaching a W14 beam to the side of another W14 beam. What's the best way to go about this for a crane application?
Should I be adding an end plate to my monorail beam, boxing in the side of the header beam, and having a bolted connection there? What are the torsional implications on the header beam if it's loaded on one side like this?
Or would I be better off coping the top and bottom flanges of the monorail beam and using a fin plate (or angles) connection welded to the header beam and bolted to the monorail beam?
Thanks!
Thanks!
