sky2020
- May 21, 2019
- 39
Consider a cable with x m length, what is the equation or the value of the reflection wave based on the cable parameters? Do you have a reference to compute this? What can be the reason for a two pu transient voltage at a motor? Only wave reflection? I have no filter attached at the drive output. Is there a reference?
How would you design a good filter? What are the good filters in the market? Just an inductor? LC Filter? dv/dt filter? Wave trapper? a combination? How it can help reducing motor heating, motor noise, and motor vibration? Can you please direct me how the LC for a dv/dt is computed and sinewave LC are computed? For me, both are the same!
