Motor 2
Book on Machine Design / Design of Machine Elements may contain information you seek. I say "may", because not all the authors give tolerancing enough attention.
Also on this forum, in general, but again, in general, the members are discussing ASME Y14.5 (vast majority) --and its related standards, 14.8, 14.43, 14.41 etc.--- and ISO GPS standards which are dimensioning and tolerancing tool kits (not an engineering design manual).
Maybe you would have more success if you try to post the same question on other area on Mechanical Engineers section on eng-tips. See the list below: I don’t know….just a suggestion.
Activities
Mechanical engineering other topics
Pipelines, Piping and Fluid Mechanics engineering
Boiler and Pressure Vessel engineering
Heat Transfer & Thermodynamics engineering
Pump engineering
HVAC/R engineering
Valve engineering
Mechanical Acoustics/Vibration engineering
Drafting Standards, GD&T & Tolerance Analysis
Gear & Pulley engineering
Bearing design, manufacture and maintenance
Mechanical Seal engineering
Fluid Power engineering
Gas compression engineering
Storage tank engineering
Laser engineering
Ignition, Combustion and Detonation engineering
Optical systems engineering
Gas distribution engineering
