They are called "brake motors" and have an integral spring loaded friction brake attached to the back (non-drive) end. The brake is help open by the same power going to the motor, so when you energize the motor the brake is released, when you de-energize the motor the brake is set. These are very common.
But as others have mentioned, a worm gear usually doesn't need one and on a satellite dish I have to imagine you have a very high gear ratio. Worth considering.
