Jun 9, 2021 #1 helpyou Automotive Sep 26, 2011 79 0 0 QA HI what is the difference in MOV setting configuration between close setting at position limit and torque value. Thank you
Jun 9, 2021 #2 danw2 Industrial Oct 21, 2004 1,505 0 36 US There's likely a logical AND function for the two switches: if either trips, the motor stops. The torque switch can trip before the actuator shaft reaches its limit, whereas the limit switch is a physical position limit. Upvote 0 Downvote
