mike mufdi
We are installing a new oil manifold which has MOVs in inlets and test header outlets, Contractor is insisting on including the MOVs in the hydrotest of the manifold. is there any precautions needed or are we putting the valves in any serious danger by not dropping the valves? Project designed on ASME B31.3 and shell DEP. class rating 1500lb , testing at 340barG
