HouseBoy
- Nov 21, 2005
- 464
I spec'd the Simpson Moment Post Bases (with the associated reinforcing around).
The contractor thinks he can position the posts more precisely if he can simply embed the posts into the pier foundation (with concrete AND a protective sleeve).
(This is for a 25 ft x 15 ft pavilion - A fancy patio roof)
It seems that the moment capacity and stiffness should be similar in that the piers would be similar and the limiting factor would be the 6x6 itself.
Has anyone used "Post Protectors" or a similar product?
Mainly interested in how they might affect moment and uplift resistance. (I have 10 posts total) Drift is prob L/150 under design load. Should be fine for the intended use.
Thoughts about these two options?
