ReverenceEng
I have a situation where I need to sharpen my pencil and try to make use of the increase in capacity for loads in the transverse direction to a fillet weld, but with multi-axial loads. Normally, we would stick to the "traditional" shear capacity of the weld for these more complicated situations, but here, I need to see if I can do more since there is an existing condition.
For clarity, I am speaking about using this equation: Fw = 0.6*Fexx*(1+0.5sin(theta)^1.5)
However, generally, when we "see" this equation, we are usually working with a resultant force vector that has a component along the longitudinal direction of the weld and another component transverse to the weld where the transverse component which would "receive" the increased capacity is parallel to one of the legs of the fillet weld (straight up or to the side). I would consider this the "typical" application as I have sketched in the attached.
In my situation, I have a multi-axial resultant force vector, so when we break it down, we have one component longitudinal to the weld and TWO components transverse to the weld, one parallel to each leg. Thus the "transverse resultant" would no longer be parallel to either leg, but depending on the magnitudes of the components would fall somewhere between and extend "through" the throat.
My question(s):
1) Is this equation still applicable even though my transverse load is not parallel to one of the legs of the fillet?
2) If so, which angle is not the "theta". Is it as I have shown in the attached sketch between the resultant force vector and the longitudinal axis, or is it perhaps "Beta" as shown in the attached, which is the angle between the resultant and the plane. I think it should be theta as I have shown it, but I also think I have thought about this too long and have turned myself around.
Help much appreciated!
