Hi everyone,
Hoping to get some feedback on nameplate design as it applies to multi-chamber vessels, when one of the vessels is non-Code (ie. under 15 psi).
We have an ASME CoA for U/U2 work, and one of our registered designs (hey, we're in Canada) is for a 50 psi jacket that we use in steam fired vessel applications. Usually, the 50 psi jackets are applied to a vessel that itself is only rated for atmospheric conditions (ie. contains a vent, manway does not retain pressure, etc).
So in terms of the nameplate, UG-116(j)(2) of the 2019 BPV Code states that process information for chambers of multi-chamber vessels not covered under the scope of the Division can be grouped with the information for chambers that ARE covered under the scope of the Division, but "provided they are not included in the markings covered by the Certification Mark."
My question is, how clear must the separation be between the information "covered by the Certification Mark", and the information that isn't covered by the Mark? Can I put all the information on the same nameplate as long as the layout of the information on the nameplate shows a distinct delineation between the two? Or are we talking a physical separation like two physically separate nameplates that are installed next to one another? Has anyone ever had this discussion with ASME or their AI, or knows of a code case where this is explored further? (I couldn't find one.)
TIA,
Sean
TIA,
Sean
