NickParker
When generators are operating in parallel , neutral contactors are interlocked with generator breakers to ensure that only one generator's neutral is connected to earth to eliminate circulating currents. What happens if a Line to ground fault occurs within a Generator whose neutral is not grounded?
Do the other unfaulted generators trip? or only the faulted generator gets tripped?
