Multi-mates
Tmoz
NL
Hello, I work with Solid Works 2007, and I'm wondering if it is possible to mate your selection in the way of the linear pattern function. THis is because I want to make a assembly with 150 wheels, 150 axis and 150 holes. I don't like to import all of the 150 wheels and axis and mate all those selection in one assembly. So my question is simple: Can this faster?
Are the holes patterned in one component?
If they are you can use the Insert > Component Pattern function using the Feature Driven option.
[cheers]
