abusementpark
- Dec 23, 2007
- 1,086
For an exterior multi-story wood shear wall, is there any issue with the horizontal joint of the sheathing occurring at the floor truss space, as long as blocking is provided between the trusses at the joint? This would be for 4'x8' sheets oriented horizontally. I have seen where some engineers do not allow the joint to occur at the floor. They want the sheathing to be continuous from the top plates of the lower floor to the bottom plate of the upper floor. Is there any reason for this?
Also, is there any reason to require the layout of the sheathing panels to have staggered end joints? I have seen in SDPWS where this is requirement for gypsum wallboard, but don't see anything requiring that for wood sheathing.
