We have stepper motor driving a lead screw that requires resilience to power failure and the ability to re-start and still retain its position data.
I've been looking at multi-turn encoders but they're big and expensive.
Is there an alternative way to track the position of a shaft over a max of 10 rotations? I had thought about using a standard 360 degree encoder with a reduction gear to prevent it from turning more than 360 degrees... but we would then need a ROM/capacitor setup of some kind to store the position data until power up
Anyone done anything similar?
