Prot123
- Jul 25, 2018
- 42
What will be the impact of having multiple grounding source connected to Substation bus during normal/fault condition. the situation is:
a. 6.6kV generator connected to the bus with its neutral grounded
and
b. 6.6kV LV side of 3 winding transformer connected to the same bus. The LV neutral grounded through a NE Resistor. 3 winding transformer, HV(star ungrounded) of which being feed from another generating source few km apart. Tertiary buried delta to provide zero sequence compensation.
and
