EmpiricalEngineer
I'm needing some help to understand what is going on with some old calcs I'm reviewing. The structure is for an old timber roller coaster which is made up of hundreds of frames along the length of the track. The way I see it I think the wind loading Cf should be based on ASCE 7-10 29.5-2, with that wind pressure applied across the structure at every member. However in the older calcs I am seeing the Cf factor used as being 1.8 and for each layer in the depth of the bent frame, the Cf factor becomes Cf+Cf^0.8, Cf+Cf^0.8+Cf^0.8^2, Cf+Cf^0.8+Cf^0.8^2+Cf^0.8^3, etc. I would then assume that wind pressure would be divided up by the designated number of layers and then applied across that structure specifically. Very tedious and time-intensive, but the wind pressures I'm getting between the two methods would save 25% or so throughout the structure which is obviously something the original designer understood. Does anyone have any insight into where I can find the explanation of this Cf calculation?
Thanks!
Thanks!
