rockman7892
I have a situation where we need to connect (2) SEL-787 relays to the same CT. These are two primary feeds to a transformer (through an MTS) that are sharing the same secondary CT. Therefore there are two parallel overlapping differential zones with CT’a on each feeder and secondary CT driving (2) relays (one on each side)
The (2) relays are connected in series off of each single CT. What happens if the first relay in series fails or is de-energized? Will will that interrupt current flow to 2nd relay or does current continue to flow through 1st relay even though it is off?
Any other considerations or challenges in this arrangement from those that have had experience?
