I am trying to figure out how to put multiple small openings in a pressure vessel and I am having a hard time figuring out what sections of the code apply to what I am doing.
Design pressure - 500 PSIG
Design Max Temp - 200 Deg F
C.A. - 0.00"
MDMT - -20 Deg F
Carbon Steel Vessel: SA-516-70, 0.626" THK Shell 36" OD Horizontal
I am trying to put a 16" gas dome on top of the vessel without putting a 16" hole in the shell. So underneath the gas dome i want to pop in a couple 2" OD holes. 1 in the center along the center line of the vessel and then 6 equally spaced around the center hole. The pitch between the holes will be 4".
Per UG-36(c)(3)(-a)(-2) my opening would not require reinforcement other than inherent. So I have calculated the UG-40 Limits of Reinforcement UG-40(b)(1) as "d" the diameter of the finished opening only because i have no nozzle in the hole, just an open hole. So would it be correct to assume that if I place my holes such that I have 4" pitch, 2" OD hole - 2" gap - 2" OD hole, that I would not have a shared reinforcement situation and therefore I can stick with just UG-36(c)(3)(-a)(-2) and not need any additional reinforcement? Or am I completely missing something and need to take into consideration UG-53?
Thanks in advance.
C.A. - 0.00"
MDMT - -20 Deg F
Thanks in advance.
