aabaig2022
Aerospace
Linear Static Analysis Users' Guide of MSC Nastran states that it internally generates MPC equations for all RBEs used in the FE model. Is it possible to view these internally generated MPC equations?
Why do I want to view these MPC equations?
There is a problem solved in the Linear Static Analysis guide with both MPCs and RBEs. I have attached the screenshot for your kind reference. I want to know, when using RBEs, how does MSC Nastran internally generates these equations? For example, in the RBE approach there is no mention of 0.5 unit distance (highlighted in the attached image). How will MSC Nastran determine this when internally generating the MPCs?
Thank you.
Thank you.
