MV Synchronous Motor Starters
2esingeek
Good afternoon All,
I am trying to get a budgetary price to my client to replace two (2) MV Synchronous motor starers that will source two (2) 1500HP Motor loads. I haven't had to buy them in 10 years and would not know what the pricepoint is. I threw out bobbers in the water to my Rockwell and Eaton contacts but with the current crisis response time is a little slower than normal. If anyone has input to a rough order of magnitude as to what the owners cost for this is please share.
Thank you Jason
Across-the-Line, RVAT, Reactor Start, Soft Starter?
With or Without a Motor Protection Relay?
Across-the-Line, no MPR, 1 high structure, figure $20k worst case scenario.
Add another $10k for an MPR with CTs, PTs, RTD inputs etc., like an SEL 710 of Multilin 869
Oh wait, forget that, I just saw the Synchronous...
Brushless or brush type? Excitation with the starter or is it external?
Synchronous motors and 1500HP rating - must be low speed type.
If these are induction started (Induction-start, synchronous run) and source is good enough to allow DOL start, there is no difference between the starter for Squirrel cage induction motor and that for Synchronous motor.
Has the Polarized Field Frequency Relay gone the way of the dinosaur?
Bill
"Why not the best?"
Jimmy Carter
The starter would not be different, but the appurtenances would be.
I contacted a very helpful MV Technical Sales Engineer at Motortronics and said that a MV Brush Type Synchronous Motor at 2300V 1500HP at 514RPM with 38R Fuses and 125V Field Excitation voltage at 124A could be around 50,000. I am still trying to get prices from AB and Eaton.
Sorry SEL 710-5 and its Across the line
In the $50-60k range could be about right for what we'd sell an ATL synchronous starter for. The price can depend on the options. You're hitting a current level where some of the component prices quickly jump.
