JHoward_UNT
Bioengineer
Hello ,I was wondering if anyone could help clear up some of my confusion on this. I'm trying to create an accurate representation of the myocardium using correct material definitions and parameters of the myocardium, and the myocardium is often described as anisotropic hyperelastic which is why I choose to use the Holzapfel equation. In Abaqus, the Holzapfel equation is defined using variables such as c10,k1,k2, kappa and D. However, everywhere else the Holzapfel equation is defined with variables such as afs,bfs,as,bs,a,b,af and bf and this is the area of my confusion, because their both defined as the strain energy formula for the Holzapfel equation but their variables are different as well as their variable definitions. Thank you.
