Hi all,
I work as a metallurgist and we've received an RFQ for 4130. The tensile requirements should be a cakewalk- 85 KSI UTS, 45 KSI yield, 15% elongation. My concern is the charpy impact requirements - 20 ft-lbs at -4°F. We do not have the ability to quench this size casting so it would be normalized at 1650°F, air cooled, and tempered at a temperature to be determined. The test material will come from separately cast keel blocks that will be heat treated along with the casting.
Thanks!
Thanks!
