NACE MR 0175
majid12345
Chemical
Jul 14, 2004
4
IR
Hi
Crude oil pipeline is sour and there are some storage tanks in terminal. Can we exclude NACE from these tanks? There is a table that exclude storage tanks in NACE MR 0175 but for flow lines not transportation pipelines.
Suggest You consider posting this question within the Petroleum Engineers and/or corrosion engineering forums
Regards, Wil Taylor
o Trust - But Verify!
I have this order where data sheet says heat tratement as per NACE requirement, Is post weld heat treatment necessary for Hatealloy C276(N10276) material necessary as per NACE MR175/ISO15156
