  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
NACE SP 0403
Flo65
Industrial
Dec 10, 2008
16
GB
I am looking for valves manufacturers of valves (check and gate) which could be compliant with NACE SP 0403.
Usualy our valves are in accordance with NACE MR0175 & MR 0103 and I do not know where I can find those valves (short delivery needed !).
Thank you in advance.
What is the property you are expecting for a NACE SP0403 compliant valve?
I think such a compliance is not existing, since you need to select a material (CS/SS/Nickel steel) using this standard. And SP0403 gives no special composition of the material which is resistant to caustic SCC.
CocoE
Hi CoCoE,
I really do not know, our Customer insist to have such valves (but we can not suceed to know why !) and usually our valves are according to NACE MR0175 or MR0103. Our main suppliers does not match with this standard and I am not sure that this apply to valves.
Regards.
