Sol71
Materials
- Apr 30, 2018
- 5
What criteria should I use to choose between NACE TM0177 Method A and C?
The background for my question is the following: We are currently using 660 D bolts (Alloy A286/UNS S66286) on one of our subsea products, it is coated. NACE MR0175 have very conservative temperature value for the use of UNS S66286, max 65 deg C/ 149 deg F. We would like to do our own testing of the material according to NACE TM0177, on elevated temperatures. I know that FMC Technologies did this a few years back (Link) and later, a test on even further elevated temperatures (Up to 400 deg F) with a 5% NaCl Solution, 15 psia H2S. They used method C. I have some structural engineers her questioning why they haven’t used method A, since the material is going to be used for bolts. I know the principles of the two test methods, but I don’t have enough knowledge to determine which of the methods would be the best in our case or why FMC choose to use method C for their test.
Thank you.
Thank you.
