Naming SDVs (solution-dependent state variables)
Nicolas94
5
is there a way to give a name to the SDVs in field output? For example SDV1 = FiberDamage.
Thanks inadvance and kind regards,
Nicolas
Yes, you can use the Tools —> Field Output —> Create From Fields option to create your own output variables based on the existing ones (SDV1 in this case). There you can specify the name for your new variable.
