proceng234
Chemical
Dear all,
I’m working on a project related to a reactor in which natural thermosiphon boiling of an organic heat transfer medium occurs on the shellside of a reactor (11 m long, D = 3.5 m, 4500 tubes filled with catalyst). The organic fluid is returned to the reactor strongly subcooled, then undergoes convective heat transfer and warms up until its saturation point after which it is evaporated and leaves the reactor via an annular ring on the top. It is condensed again in a steam generator and is returned subcooled to the RX via 2 annular rings at 2/3 and 1/3 of the RX height.
Due to a catalyst change we will need to switch the heat transfer medium. The big question is how this will affect the heat transfer and thermosiphon operation/stability, mainly in respect to the different physical properties (thermal conductivity, viscosity, mass density, specific heat, enthalpy of vaporization, …)
Any suggestions on some background reading / rules of thumb / … for making a first approximation? How to best tackle this problem?
Any tips/advice is more than welcome.
Best regards,
proceng234
Best regards,
proceng234
