palk7 EIT
- May 12, 2020
- 142
In Canada, for seismic connection force, according to clause 4.1.8.18. " connections to structure shall be designed to accommodate building deflections" and the building deflections are amplified by multiplying Rd*Ro to get the realistic displacements, so that implies that the connection forces should also be that of the amplified displacements? (Simple terms the members to be checked for Base shear / (Divided) Rd*Ro and the displacements & connections will be for Base shear* (multiplied) Rd*Ro?)
Thank you!
Thank you!
